Abnormal wear on TCI crank pilot extender.
Old Oct 16, 2015 | 09:03 PM
GMCtrk's Avatar
Default Abnormal wear on TCI crank pilot extender.
I noticed some excessive wear in my TCI pilot extender. However, I didn't find any correlate wear on the actual billet pilot of the converter. A couple things I was thinking about...is my crank flexing? Or maybe the metal of this TCI piece is suboptimal compared to the billet converter leading to the breakdown?
It's not aweful wear and I'm contemplating re-using the piece. CircleD said they could weld on an extender or they also have a replacement part for $40.
Old Oct 17, 2015 | 04:53 PM
Suburbazine's Avatar
That doesn't look like rubbing wear, it looks like galvanic corrosion, particularly the pitted areas.
Old Oct 17, 2015 | 04:59 PM
GMCtrk's Avatar
There is evidence of rubbing.
Old Oct 17, 2015 | 06:10 PM
smokeshow's Avatar
Mod with training wheels
Stock cranks are used in 1600hp builds without issue...I doubt that 75mm was flexing it. Regardless, the converter doesn't rotate relative to the crankshaft, so how could it rub?
Old Oct 17, 2015 | 06:55 PM
03sierraslt's Avatar
Maybe if there was play and the bushing was floating but that wouldn't cause it to look like that.
Old Oct 17, 2015 | 07:02 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Looks like that thing was moving around in there. Why not use one that bolts to the flexplate with longer bolts?
Old Oct 17, 2015 | 07:22 PM
GMCtrk's Avatar
The extender isn't fixated to the crank or converter, so it need not rotate with them. Also, the flexplate flexes in and out and there really shouldn't be any angular deflection but I'm wondering if there is a very small component. There has to be an explanation for the findings.
Old Oct 17, 2015 | 09:56 PM
Wolftrk99's Avatar
Possibly converter not centered in bushing, know its a long shot but would explain it...
Old Oct 17, 2015 | 11:02 PM
George C....'s Avatar
Formerly ScreamingL
Stock cranks do flex around 1000rwhp
Has your oil pressure been steady? Signs of crank flex is a loss of oil pressure typically 5 or 10 psi lower then normal when warm
Old Oct 17, 2015 | 11:06 PM
GMCtrk's Avatar
George, I haven't seen any noticeable drop in oil pressure (55 psi cold idle, 45 warm) but that's on the stock cluster which who knows if it's reliable.
