99 suburban (falls on her face)
Old Aug 10, 2005 | 09:49 PM
SSlow 4.8's Avatar
Pumps rarely go.. unless the fuel filter has been so dirty for so long that it burnt it up... have a shop check the fuel pressure and let them tell you what they find.
and Cut the damn cats off.. sheesh, lol jk.
Old Aug 10, 2005 | 10:34 PM
James B.'s Avatar
Is this resovled yet? Anxious to hear if I would have lost the bet or not!
Old Aug 11, 2005 | 12:04 AM
420's Avatar
420
my moms had this same problem, and if i remember, it was the maf sensor that was doing it.
Old Aug 11, 2005 | 02:38 AM
desTRUCKtive's Avatar
If it is cutting it out a certain RPM than some type of airflow must be restricting it. If it is not sput puddering at around those RPM's (for example wanting to die) than I dont think that it is fuel (if it feels like it wants to die while it is climbing on RPM than it might be fuel). I think that it might be that cats as well as some have mentioned.
Old Aug 11, 2005 | 02:47 AM
oh are you getting any codes. i would run a scan and see if you have any missfire codes... if you do and eliminate all the stuff that could cause a missfire code, example plugs wire cap and rotor. after all that is done. I would replace the ignition control module. The ignition control module on these controls the dwell output, one of these wires on the module could have gone bad. When they do go bad they will not want to pull anymore under load.
I had a friend that this happened and it turned out to be this. He would get a check engine light when he would go uphill and would start missing.
Hope that helps a little. BTW thanks for changing your avatar... that dude you had on there bugged the hell out of me.
calsdad
Jun 14, 2023 11:07 PM
thompson
Dec 27, 2017 06:48 AM
cheyenne383
Nov 13, 2015 09:24 AM
1989k1500
Sep 29, 2015 10:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
