99 lq4
Old Jan 26, 2015 | 10:28 PM
madracer402's Avatar
Default 99 lq4
Im trying to find a shop to make me a 3000 stall converter to bolt up my 99 6.0 (lq4) to my 4l60e.. Anyone know of anyone or tricks to get this to work???
Old Jan 26, 2015 | 11:01 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Did you try contacting Circle D? They are a sponsor here and can probably get you set with what you need.
Old Jan 27, 2015 | 11:23 PM
I havent yet but ill give them a call.. I cant believe there isnt a stock solution for this.. I guess its just gonna be another $1,000 fix lol
Old Jan 28, 2015 | 09:34 AM
GMC93's Avatar
TB stall will prolly stall to 2700 or so behind an lq4. I paid 100$ plus a 100$ core charge for mine. Daaco I think is the brand.
Old Jan 28, 2015 | 05:12 PM
and that would work with the longer crank issue of the 99-00 lq4 so i can use my 4l60???
Old Jan 28, 2015 | 05:16 PM
Who would you guys recommend i use for my e-fan harness? Im using 05 silverado e-fans ..
Old Jan 28, 2015 | 07:21 PM
Flyingcat's Avatar
2003-2013 Full Size Truck Dual Fan conversion kit
High quality.....priced right and Alvin has a manual switch option now
Old Jan 28, 2015 | 09:21 PM
thanks ill be calling him tomorrow..
Old Jan 28, 2015 | 09:34 PM
As far as a oil pump goes im going to order a ls6 one , do i need a high volume and high pressure pump or just high pressure? Do I need a new/ better pickup tube also?? Its a 99 6.0 ,stock 243 ,bigger springs(.625) ,228/230 585/585-112 cam,ls7 lifters,trunion kit, ls2 chain
Old Jan 28, 2015 | 09:37 PM
GMCtrk's Avatar
Use a stock OEM harness. Integrates perfectly with the electrical center, and high quality relays - no worries about them blowing and leaving you overheated on the side of the road
