98 Z71 mods
Old Feb 11, 2004 | 02:22 PM
ALPINE's Avatar
Default 98 Z71 mods
My roommate is wanting to drop a grand or two in his 98 Z, its got the 350. Does anyone know where to go with this older pickup? We were thinking cam, long tubes, gears... any info would help, I have no experience with that powerplant..
Old Feb 12, 2004 | 12:52 PM
ALPINE's Avatar
TTT If noone know about the older ones, anyone know a board I can look at? Thanks,...
Old Feb 12, 2004 | 12:57 PM
Pro Stock John's Avatar
Registered User
A few of us have the 96-99 5.7 L31 engine.
I've done a UPD airbox, 3.7'3's, eaton posi, hooker aerochamber muffler and I have a yank 2800 stall in the box. I'm hoping for low 15's in the Tahoe.
Old Feb 12, 2004 | 01:07 PM
I use to have a 97 z71. First unless your going to bigger tires dont mess with the gears. You already have 3.42 or 3.73 and its really not worth it. I would personally make it faster by cam, heads port and polish, nitrous. Sounds about right. You should be more specific what you w3ant out of it. just to go fast or to still off raod, bigger tires etc.....
Old Feb 12, 2004 | 02:09 PM
zippy's Avatar
i'd say cai with headers and a good cat back. LT1 cam (a bit of a hp bump usually found for about 35 buck's used and ok with stock valve springs) with a bit of port work on the heads. 2800 stall and a 4.10 gear with programming and shift kit/servo's. should be enough to get somewhere. if you need heads, go fastburns or e-tec's from edelbrock as a bolt on aluminum.
Old Feb 12, 2004 | 02:12 PM
Registered User
Catback or a muffler and an airbox work for sure, my 99 tahoe is faster for sure.
Old Feb 12, 2004 | 09:35 PM
Have you looked at www.fullsizechevy.com yet? they have a thread in the performance section of the forums for the OBS. if you have any questions my brother has a 96 that has a few mods (I'm under the same user name there too). A program will help you realize the potential of the mods once your done
Gerry
Old Feb 13, 2004 | 01:38 AM
ALPINE's Avatar
Gerry
Word, thanks guys, I just needed some advice about the process. I've modded my SS soley by adive I get here, and my ****'s BAD. Thanks for the board refrence and the brand names to go with laters.
Avalanche2002
Nov 30, 2015 07:31 AM
cheyenne383
Nov 13, 2015 09:24 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
bisqikss
Sep 27, 2015 09:40 PM
