95 model gen5 454 oil cooler lines
Old Dec 21, 2008 | 11:22 AM
jakemanor's Avatar
Registered User
Default 95 model gen5 454 oil cooler lines
Installing a 95 454 in a 81 truck it has oil cooler lines coming out of the block by the oil filter can i block these off without killing the engine of do i have to loop them for return flow !
Old Dec 21, 2008 | 03:30 PM
L7 Sierra's Avatar
Loop them atleast. Or you can add a oil cooler to help your motor.
Are you sure this is not a bolt on cooler kit that you can remove?
Old Dec 21, 2008 | 09:37 PM
xx_ED_xx's Avatar
you can block them off but.... you need to remove the bypass directly below the oil filter screw in fitting. Send me a message if you need help. if you dont oil pressure will be an issue and not in a good way
bighouse
Sep 27, 2015 12:37 AM
zaathur151
Aug 12, 2015 06:32 PM
05GMC4.8
Aug 7, 2015 09:55 PM
ullose272
11
Jul 17, 2015 07:22 AM
Mzay
Jul 6, 2015 11:03 PM
