94 chevy 350 tbi rebuild question
Old Jun 21, 2014 | 01:23 PM
94ChevyC1500's Avatar
Default 94 chevy 350 tbi rebuild question
Okay so I got an engine rebuild on my 94 chevy 350 since they found play on my crank, which was causing a mess of an oil leak, so they put flat-top pistons, bored out the block .40 over, and an elgin prostock cam, lifters&springs, heads got machined as well, pretty much the entire rebuild on the motor, guy said it should all work fine with the TBI, with that being done though since I am making a more performance engine, would I need a tune or would it run fine like that, I did replace the injectors, fuel pump, put a tb spacer, injector spacer, longtubes, dual exhaust, and cold air intake on it, new ecm and entire engine harness, and entire ignition system is new as well
Stainless Works
13
Nov 5, 2015 03:31 PM
USMCvet0311
Aug 1, 2015 07:45 AM
SleeperGMC
Jul 29, 2015 10:22 AM
4B11T
Jul 13, 2015 03:48 PM
