92mm Intake?
So after I put on my NNBS intake, corvette filter, ect ect and my new FAST 92mm throttle body, I found out that no amount of WD40, KY or baby oil would get my regular intake tube ON that bigass thing.
Who makes a intake tube that goes from the factory 3.5" MAF to a 92mm throttle body? (Keep in mind I have the old water pump driven fan setup and NO efans)
I've already messed around Lowes and Fastenal and came up with nothing.
Since you're running a stock fan clutch & shroud, I'd look for the AirRaid MIT. You may need to get a silicon boot to connect it to your throttle body, but I believe the one it comes with will work just fine for you.
Nah, ended up using the NBS fuel rails and modifying the line to work. Sucks because I had to "fab on the fly" after already taking a nnbs rail and corvette filter and shortening the line to keep it "clean" but oh well.
Probably going to look for some 42lb NNBS injectors and clip adapters to use the nnbs rail. Also need to make and weld up a better cable bracket as mine isn't as tight as I would like it and doesn't open 100% (more like 80%).
Honestly had I known it was going to be this big of a pain in the ***, I wouldn't have done it. I better see another 20rwhp after I get it retuned with this intake/throttle body. Definitely my last mod until I buy a damn supercharger or switch to LS3 heads/intake.
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
