92mm Intake?
Old Feb 15, 2014 | 11:52 AM
SamuelsonMotorsports's Avatar
Default 92mm Intake?
So after I put on my NNBS intake, corvette filter, ect ect and my new FAST 92mm throttle body, I found out that no amount of WD40, KY or baby oil would get my regular intake tube ON that bigass thing.
Who makes a intake tube that goes from the factory 3.5" MAF to a 92mm throttle body? (Keep in mind I have the old water pump driven fan setup and NO efans)
I've already messed around Lowes and Fastenal and came up with nothing.
Old Feb 15, 2014 | 01:18 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Since you're running a stock fan clutch & shroud, I'd look for the AirRaid MIT. You may need to get a silicon boot to connect it to your throttle body, but I believe the one it comes with will work just fine for you.
Old Feb 15, 2014 | 02:12 PM
FML. Just found out my marine injectors are too short to work with the factory NNBS fuel rail and intake. GREAT. I already fabricated the fuel rail to go returnless... for no reason.
Old Feb 16, 2014 | 10:50 PM
Iconic Motorsports
you can get extenders
Old Feb 17, 2014 | 12:02 PM
Nah, ended up using the NBS fuel rails and modifying the line to work. Sucks because I had to "fab on the fly" after already taking a nnbs rail and corvette filter and shortening the line to keep it "clean" but oh well.
Probably going to look for some 42lb NNBS injectors and clip adapters to use the nnbs rail. Also need to make and weld up a better cable bracket as mine isn't as tight as I would like it and doesn't open 100% (more like 80%).
Honestly had I known it was going to be this big of a pain in the ***, I wouldn't have done it. I better see another 20rwhp after I get it retuned with this intake/throttle body. Definitely my last mod until I buy a damn supercharger or switch to LS3 heads/intake.
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
bisqikss
Sep 8, 2015 03:35 AM
turbo truck
Sep 2, 2015 09:58 PM
