918's do they cause valvetrain noise
Old Oct 27, 2004 | 02:13 AM
Ryan23silverado's Avatar
Oh ya you will hear them. And like others have said, it will sound like a sewing machine.
An aggressive cam profile (opening valves to max lift quickly and then snapping them shut) generally makes this sewing machine noise more pronounced simply because of the fact that the valve is being accelerated back up into the valve seat at a higher velocity before it hits the seat. This gives it a nice ticking noise that is oh so lovely
Old Nov 12, 2004 | 09:13 AM
BigTex's Avatar
You know, for the most part my 918s are pretty quiet. I can hear them if I have the hood up and listen. I am running a .563 lift cam and titanium retainers with hardened 7.4" pushrods. Sometimes the noise is a little louder than other times, not sure why. Most of the time when I hear something, its a distinct tapping from the passenger side only, not so much the sewing machine effect.
Old Nov 12, 2004 | 10:24 AM
gonzo 6.2's Avatar
APE heads with 918s and Ti retainers 220/550 114LC,sounds like a sewing machine(buddys denali).If I ever change cams I will go with late yellow LS6 springs.I like quiet.With the small cam I have and blue LS6 springs my valvetrain is completely quiet more so than the stock 5.3 ever was.This maybe due to the heads shaved .020 tighting the preload.
Old Nov 12, 2004 | 02:05 PM
BigKID's Avatar
Like Ryan said, I think it has more to do with the cam shaft than the springs. However a spring with higher seat pressure coupled with an agressively lobed cam will bring the valves in harder producing a little more noise that a the same cam with a softer spring. On the same note, a stiff spring with a lazy lobed cam could be very quiet.
With that being said.. my FMS cam w/918s has some pretty sugnifficant valve train noise.
Old Nov 12, 2004 | 02:59 PM
rcsb4.8to6.0's Avatar
bigkid what fms cam do you have: mine is the 220/220/114 +4. at times the noise does seem to be louder than others who knows. i will bring the truck back to allen futural and let him look at it and tune it again, then run it tills it blows up.
Old Nov 12, 2004 | 10:47 PM
mdhmi's Avatar
No noise from my 918's.
Mark
Old Nov 13, 2004 | 10:19 AM
BigKID's Avatar
Allen and I put our heads together and came up with a 214/216 .535/.545 113+4
Old Nov 13, 2004 | 11:16 AM
Kano's Avatar
you have to really listen to hear mine
same as above sewing machine sound
Old Nov 13, 2004 | 04:24 PM
Mr. Sandog's Avatar
Mine are no louder than stock.
Old Mar 9, 2005 | 11:22 PM
02sierraz71_5.3's Avatar
Mine is loud its especially noticable when I pull up next to something. More preload, longer pushrods will quiet it down though you run risk of more wear.
I have a aggressive cam 222/222 .566/566 lingenfelter gt2-5
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
