90mm maf???
Old Feb 2, 2008 | 08:41 PM
jkwalkercchs's Avatar
idk thats a good question???
Old Feb 2, 2008 | 08:47 PM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by DrX
Isn't the stock MAF 90mm?
85 seems to stick in my head.
amadeospike's Avatar
Will he be able to use the 90mm SSR TB. Have you figured out a way to make them work?
Old Feb 2, 2008 | 08:49 PM
yea itll work thanks to drx
trever1t's Avatar
2nd fastest 5.3 ECSB
I guess the real question is if the stock MAF with screen is a restriction in a 90mm/4" intake system?
Old Feb 2, 2008 | 09:09 PM
idk has someone done any research on this??
Old Feb 2, 2008 | 09:18 PM
I thought I had to change my MAF when I did my LS2 swap, but everything fit perfect and you should be o.k. with your stock MAF sensor. I took the screen off, but just make sure you get it tuned to make sure your A/F is on the money. The O/D on the 78mm is the same as the 90mm but the inner diameter changes. At least that holds true with my truck. My K&N kit fit like a glove on the 90mm LS2 TB.
Old Feb 2, 2008 | 09:23 PM
im probly gonna ditch the k&n and get somethin customs
Old Feb 2, 2008 | 09:47 PM
DrX's Avatar
DrX
I just went out and dug up my stock MAF. It is 90mm I.D. at the most narrow point.
I read that the gains from descreening the MAF are insignificant. Largest gain seen was 4hp. And it can really mess up the airflow measurement. This is by an automotive engineer/custom tuner.
Old Feb 2, 2008 | 09:49 PM
so just leave my maff alone? dont get a bigger one
