87 octane with boost
Old Feb 6, 2018 | 11:19 PM
Crysis450's Avatar
Default 87 octane with boost
I have a 5.3 with a 76mm turbo mild cam bigger fuel pump and injectors, my question is can i run 87 octane with 8psi and a conservative tune or should i just go with 91 or even e85?
Old Feb 6, 2018 | 11:31 PM
FFDP's Avatar
Why risk anything?
You'd likely have to drown it in fuel or run like zero timing to be knock free on 87 octane. Run 91+ to keep it safe and spend the extra 5-8 dollars a tank.
Old Feb 6, 2018 | 11:56 PM
Crysis450's Avatar
Originally Posted by FFDP
Why risk anything?
Yeah it will probably even get better mpg on 91 and make more power
Old Feb 7, 2018 | 05:47 AM
MrHorsepowerLSx's Avatar
11 Second Club
I doubt that it will get better MPG, but it will have a better chance of survival, and the window to make more power will be there. You could always hook up a meth kit as well, if needed
Old Feb 7, 2018 | 07:19 AM
smokeshow's Avatar
Mod with training wheels
Running 87 octane in mine lol. More of an experiment to see what I can get away with though. However I already know my setup is very knock resistant, so it didn't exactly get 87 on a whim...
Old Feb 7, 2018 | 07:37 AM
MikeGyver's Avatar
What makes your setup knock resistant, oh Mr. No Signature?
Old Feb 7, 2018 | 07:44 AM
smokeshow's Avatar
Quench, tumble and low compression.
Old Feb 7, 2018 | 07:50 AM
MikeGyver's Avatar
Old Feb 7, 2018 | 07:55 AM
MikeGyver's Avatar
I have been wondering if my new pistons are too far from the heads to give adequate squish at my compression (10.5:1). My old setup at 10.3:1 didn't knock, the new one rattles at around 4000 rpm. It goes away with a 50/50 mix of 93 and 100 octane.
To the OP, be careful!
Old Feb 7, 2018 | 08:35 AM
03sierraslt's Avatar
What’s your quench?
My 370 is .045
I was wanting mid to low .040’s, I was less concerned with a billet rod. If a stock rod then that’s a bit different. My current motor seems to be less knock prone and it’s 10.0-1 vs 9.4 on the old.
