80 PSI fuel pressure with the engine off?
#32
#33
#34
A MagnaFuel 4303 won't do it. I'd be interested to know if you were able to make the pump run continuously, if the pressure would continue to build. If it did, that would indicate a possible blockage. If it maintains 80 psi, that would indicate a restriction, or partial blockage.
#35
#36
Once the regulator sees vacuum, the pressure will come down. KOEO pressure is always higher than KOERunning when using a vacuum referenced regulator.
70psi KOEO is a tad high.
peace
Hog
peace
Hog
#38
Just a bit, it was enough to pop one of my fuel rails off once. I can't imagine what 100+ would damage had I driven it and got into boost, but I don't want to find out.
#40
