8.1L no start? suggestions?
Old Dec 5, 2008 | 09:09 AM
Kerr's Avatar
Default 8.1L no start? suggestions?
So my suburban will not start.
Turned the key it cranked and cranked and cranked... then fired but sounded like it was on 4 cylinders, then died.. Tried to fire it again nothing happend then the battery went dead... old battery needed a new for long time.
So i got a new battery. Crankes it over like a pro but no fire... figured the wife drove it last so maybe its out of gas( the gauge doesent work).
Put 5 gallons in nada...
So where do i start to look for a problem, or is it easier to just have it towed in and let some one fix it. I dont have a lift and it like *28 out side.
On a side note i cant hear the fuel pump click on. One of the local dealer said you cant hear a fuel pump. However on mine you use to hear something every now and then turning on and off. I thought it was the airride crap but its a 2500 sububran so i have leaf springs.
Old Dec 5, 2008 | 09:13 AM
KLUG'S SS's Avatar
FormerVendor
Might be a good chance that it is the fuel pump that is bad.
Old Dec 5, 2008 | 10:06 AM
Fireman31's Avatar
+1 for a bad fuel pump
You should hear the fuel pump prime itself when you turn the key to run. Try wrapping on the bottom of the fuel tank with a rubber mallet while someone is cranking the truck over, that works many times when a fuel pump is DOA.
Old Dec 5, 2008 | 10:40 AM
wastedrubber's Avatar
9 times outta 10 if it is your fuel pump you'll get a little extra life out of it that way. or, and i don't really recommend it but i've done it before, spray some starting fluid in your intake and that'll prime your fuel pump when you start it. but do that at your own risk. i did that in this 97 jimmy i used to have for like a month while i was too cheap on time and money for a fuel pump. but pound on the tank first.
Old Dec 5, 2008 | 02:46 PM
Kerr's Avatar
thanks guys. ill try that. Its a huge bitch to push lol...
Old Dec 5, 2008 | 05:06 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Might be a bad Crankshaft Position Sensor. Very common for them to die in older 8.1's. Pain in the *** the replace too. It's stuck between the firewall and back of the driver-side head. There may be a recall on it:
http://www-odi.nhtsa.dot.gov/cars/pr...rintVersion=NO
http://www.chevyavalanchefanclub.com...c,93037.0.html
Old Dec 5, 2008 | 06:34 PM
TieRod's Avatar
If you don't have at least 50 psi it won't start.
Old Dec 5, 2008 | 07:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
X2 common problem on these as stated... Especially since you can aleast hear the fuel pump motor...
Old Dec 5, 2008 | 09:18 PM
litreddevil's Avatar
Banned
beat on the bottom of the tank with something and see if the pump comes on are it may start.if not check the feul rail see it has schraizer(ms)valve and see if fuel comes out.
Vash3233
Sep 22, 2019 01:18 PM
adunphy
Feb 22, 2016 06:38 PM
treylittlefield
Jan 24, 2016 07:38 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
