8.1 Injector ?'s
Old Aug 21, 2003 | 09:35 AM
Scream's Avatar
MOOBIES Moderator
Default 8.1 Injector ?'s
Will the 8.1 injectors support 400-450hp? I've seen some conflicting numbers on their flow.
I really don't want to pony up $400+ for new injectors that are waaaay to big for what I need.
Old Aug 21, 2003 | 10:12 AM
gonzo 6.2's Avatar
Default Re: 8.1 Injector ?'s
Scream.I was reading some current rag artical and they built a LS1 and install what i thought were 3.8 supercharged (GTP,FWD regal) injectors,they made it sound like they bolted right in.Maybe someone here knows about this.
Old Aug 21, 2003 | 10:23 AM
Scream's Avatar
MOOBIES Moderator
They probably would bolt into the LS1 fuel rail, but I'm using the truck fuel rails/intake with the "stubby" injectors. The only choices that I've found so far are:
*stock 8.1 injectors
*AS&M 43#/hr injectors = $52 EACH
*Racetronix flow matched, coming soon, no price
I would really prefer to stay with a stock-style injector, and I'm definitely staying with the truck intake/fuel rails.
Any other ideas? For my target HP, I should need a 36#/hr or so injector, and I can't seem to find anything within +/- 5#/hr of this number.
Old Aug 22, 2003 | 02:07 AM
Racetronix's Avatar
LS1TECH Sponsor
The price was posted a few days ago.
The injectors are 38lb/hr @ 43.5PSI but at LS1 pressure of 58PSI they flow apx 44lb/hr.
Old Aug 22, 2003 | 07:44 AM
Scream's Avatar
MOOBIES Moderator
Does anyone have any more info on the flow rate of the 8.1 injectors? Will they support 400-450hp?
Old Aug 22, 2003 | 01:18 PM
Scream's Avatar
MOOBIES Moderator
ttt
Old Aug 22, 2003 | 05:21 PM
Racetronix's Avatar
LS1TECH Sponsor
Yes, these injectors will support well over 500HP on a LS1 running at 58PSI.
Old Aug 25, 2003 | 01:56 PM
Scream's Avatar
MOOBIES Moderator
I'm assuming this is for your injectors...does anyone have the flow rate of the 8.1L injectors?
Old Aug 25, 2003 | 02:29 PM
hohl's Avatar
3.77 g/s as per an LS1 edit file I saw for the 8.1. Which would equate to roughly 30.15 lb/hr at our 4 bar fuel pressure. You can use those numbers to calculate the amount of horsepower they will support. Remember to keep duty cycle below 80% and use a reasonable BSFC. rceng injector worksheet
My guess why nobody answered is because it has been covered so many times. Search the archives and you would have had an answer long ago.
Old Aug 25, 2003 | 03:03 PM
Scream's Avatar
MOOBIES Moderator
I searched the archives and got conflicting answers...I just wanted to clarify.
Thanks.
