which 8.1 injector do i need?
Old Aug 27, 2007 | 12:56 PM
TXsilverado's Avatar
Default which 8.1 injector do i need?
if i can get both for the same price which should i go for?
im running 102-103 duty cycle with stock 6.0 (24lb) right now. which would do the best job? 31 or 42 lb injectors? ill be adding nitrous by next summer.
also a lil explaining of why the injector would work best would help my nooby mind.
Old Aug 27, 2007 | 01:01 PM
Zick's Avatar
I'm sure the 31's will be fine unless your planning on adding a major power adder down the road.
I ran my last truck (LQ9, TR230/224, Patriot heads) on the 31's and duty cycle was probably in the 80's.
EDIT: Opps didn't see you were adding Nitrious. Not sure how that will factor in since I've never used it before. I'm sure others can help on that.
RandomHero's Avatar
get the 42lb injectors. They won't "hurt" you unless you were running like 25% IDC(which you won't be).
However, if you just want the 31#'ers they'll support up to around 400 rwhp or so.
Old Aug 27, 2007 | 01:48 PM
kbracing96's Avatar
If your getting them for the same price, go with the 42's. You can aways grow into them.
Old Aug 27, 2007 | 01:54 PM
but will they be to big for the time being?
Old Aug 27, 2007 | 01:58 PM
silver-mod-o's Avatar
Hunt&Fisherator
they can be turned down via the PCM stew... get the bigger ones. you'll be good to go and have plenty of room to grow.
Old Aug 27, 2007 | 02:05 PM
ZZebes's Avatar
Damnit stew quit being a ***** and order the 42lbs charlie will get them tuned in right
Old Aug 27, 2007 | 02:12 PM
malibu795's Avatar
x2.......... get the 42# last thing you wanna do is run a gasser lean....
Old Aug 27, 2007 | 02:18 PM
kbracing96's Avatar
No, I run 42's in my 4.8. I know it's turboed, but under normal driving conditions it drives great! You just have to adjust the tune for them like the others have said
Old Aug 27, 2007 | 02:29 PM
bluecajun5.3's Avatar
11 Second Truck Club
31's would be fine for a good deal.
i'm running 28's on the bottle.
