8.1 Engine shutdown.
Old Dec 9, 2005 | 10:59 AM
flynn78us's Avatar
Exclamation 8.1 Engine shutdown.
What would cause this? Has anyone had this problem? 2002 8.1 2500 Avalance. While rolling down the street sometimes you get a total shutoff, with no start. The after you wait awhile it will start again. This is very intermitten problem, some days it will be fine then other days it will shut off and start right away, and other times it won't start. Any ideas would be great. I did change the fuel filter. You can hear the fuel pump engage before you start it.
Old Dec 9, 2005 | 03:37 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Probably the Crankshaft Position Sensor. It is a fairly common problem in the early 8.1 motors. The part is cheap, but I hear it is a PITA to install.
Oobray
Jun 13, 2022 03:38 AM
superchomper2003
Aug 26, 2015 09:39 AM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ammadien
Jul 22, 2015 08:50 PM
