60LB Injectors
Old Oct 9, 2007 | 11:24 PM
SpdFrk's Avatar
Default 60LB Injectors
Hey Guys,
Is there a 55-60lb injector out there that is a plug and play for my 04 6.0 with the stock intake manifold? If not what do i need to make it work? Also is the stock fuel pump enough for a motor that will make around 450 at the wheels or is there a different pump i should be running?
Thanks for any help you may have.
Old Oct 9, 2007 | 11:57 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
No. You'll need to solder new clips and raise the fuel rails. 43lb injectors and a little methanol will work fine for 450hp though.
No. Walbro 255lph intank should do it.
Old Oct 10, 2007 | 06:35 PM
SpdFrk's Avatar
trever1t,
isn't there a 42lb injector that is a plug and play? i think 42's would be the same to equal to what i have now which work fine except for the whipple stuff.
how do u like your as&m headers? were they easy to install?
thanks
Old Oct 10, 2007 | 06:57 PM
dewmanshu's Avatar
Moderately Differentiated
Static flow @ 43.82lb/hr @ 58PSI for the Delphi Multec II Shorties. Multec II is your injector plug, so plug and play!
I agree with Trever1t, you'll be fine with the 255 in the tank.
***after that, everything as of today needs new clips (I think they were EV1), so cutting and soldering is needed.
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
