6.o swap
Old Jul 1, 2005 | 08:20 PM
mason110's Avatar
Default 6.o swap
any sugesstions on a tranny to go with a 6.0? also what do you recomend as rear end gears.
Old Jul 1, 2005 | 08:54 PM
iLLuZioN's Avatar
im planning on doing the same... from what ive heard, the 4l80e is a good tranny for it... n depends on what you want to do with the truck for gears... someone else needs to chime in for that...
lemme know what you choose to do... and where are you getting your 6?
Old Jul 1, 2005 | 09:15 PM
budhayes3's Avatar
PT's Slowest Truck
I guess it all depends on how strong you plan to make the 6.0...I'd like to do one myself with a built 4L60/65E. I believe that the gearing is better than the 80E for performance, but the 80E is bulletproof!!
Old Jul 1, 2005 | 09:23 PM
iLLuZioN's Avatar
what exactly are the pros and cons of each? i mean... lets say that you wanted a truck for stoplight to stoplight racing and occasional 1/4 track racing?
Old Jul 1, 2005 | 09:53 PM
budhayes3's Avatar
PT's Slowest Truck
I'm no guru in this area, but from what I understand it's kinda as follows:
4L60E pro's - bolts right in, better gearing
cons - weak
4L65E - stronger than 60E, but not as strong as 80E by any means
4L80E pro's - STRONG
cons - gearing is less desireable than the 60E, heavier, not a direct swap for a truck that came with a 60E
Just a quick summary, hopefully someone with more knowledge will chime in
...oh yea, there's a 4L85E also...
Old Jul 1, 2005 | 11:12 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I don't believe its worth investing $1 on a 4L60 build. Too many people have had problems with them. Fortunately, mine hasn't even hiccupped at 80k miles, but if it ever gives me any problems at all I'm going for the 4L80e with the swap kit from Speed Engineering. I'm thinking it's as cheap or cheaper than a "good" 4L60 or 65e "built" trans anyway.
http://speed-eng.com/store/index.php..._940_1409_1714
Old Jul 1, 2005 | 11:33 PM
bud8fan's Avatar
im going 6.0/80e into a '93 scsb with a t76 turbo under the hood....the 80's are bullit proof...
Old Jul 2, 2005 | 03:43 AM
iLLuZioN's Avatar
i want to keep the 4wd because i live in alaska... now... do you know of other places that build these 80es complete? how much harder is it to swap it in rather than the 60/65?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
superchomper2003
Aug 26, 2015 09:39 AM
iregret
Jul 27, 2015 10:32 PM
