6.2 escalade in 2006 silverado
Old Jan 15, 2012 | 06:09 AM
kuwait's Avatar
Default 6.2 escalade in 2006 silverado
I want to install the engine 6.2 escalade in 2006 silverado
What are the pieces that we need to install the engine
Old Jan 15, 2012 | 08:22 AM
1slowz71's Avatar
The relucter wheel is diffrent so you will need one of this ...
Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module - Lingenfelter Performance
Also the thottle body is diffrent so maybe one of this ...
Torque Rush LS2, LS7, LS3 to LS1 throttle body adapter harness
I'm perty sure there a few things I'm missing like injector pig tails ect.....but the search button is your friend, I'm perty sure all this has been coverd in there good luck ....
Old Jan 15, 2012 | 11:06 AM
kuwait's Avatar
Thank you for helping me
Do I need a change Knock Sensor ???
X-link 2.1 Or X-Link NW102 for thottle body ??
Old Jan 15, 2012 | 05:38 PM
1slowz71's Avatar
I believe its the x-link 2.1
Old Jan 15, 2012 | 06:14 PM
darnie's Avatar
not to jack the thread but would that be all you needed to do the swap in a 04 as well?
Old Jan 15, 2012 | 07:03 PM
1slowz71's Avatar
I'm sure there's other things that. You will need but I don't know them since I've never done the swap my self
Old Jan 15, 2012 | 09:28 PM
10 Second Truck Club
thats about the biggest changes
Old Jan 27, 2012 | 07:31 AM
kuwait's Avatar
How much horsepower as possible be the car for installation of engine l92?
Old Jan 28, 2012 | 06:21 PM
sand man's Avatar
هلابك في المنتدى . اي خدمه انا حاظر معاك فيصل الخالدي يالغالي
just a welcomin words to my friend here
as i told you befor i dont think you need to change the every thing but the throttle body x link and thats only if you need to keep the 87mm that comes with the 6.2 motor
you can swap your 6.0 vally cover and keep your orignal knock sensors i place ( correct me if im wrong)
as for the TB you can eather go x link or add an adabter plate and run your 75mm
for the cam sensor you need the extinsion only from the back to the front of the motor , thats it i guess
Old Jan 28, 2012 | 08:38 PM
Slammed96's Avatar
You won't be able to keep the valley cover unfortunately. The GEN IV blocks have the knock sensors relocated, and there is no space to fit the old style valley cover on. Learned that the hard way...
