6.0oooooooooooooohhhhhhhhhhhhhh
Old Nov 18, 2005 | 09:09 AM
c1500's Avatar
im opretty sure mine has aluminum heads...but the tranny im using is a 1991 5 speed( i dont know the #). im putting it into my 1991 chevy fullaize. does anyone know if this will work, but i read that any tranny tat would bolt up to the older 350's and 454s would work?
Old Nov 18, 2005 | 11:13 AM
tdrumm's Avatar
The bellhousing bolt patterns are different. I believe that the old SBC has an extra hole that the Gen III engines do not.
Old Nov 18, 2005 | 12:47 PM
kbracing96's Avatar
Both new and old bell housing will bolt up, might not have the center top hole in the bell housing, but it's not necessary. You will just need to make sure the input shaft does not go into the pilot bearing to deep, or it will cause the thrust bearing to fail in the motor. If it is a little to long, you can use a grinder, or cut off wheel to shorten the input shaft some. Then as long as you have a flywheel that fits the motor and a clutch plate that fits the input shaft on the trans, your go to go.
Old Nov 18, 2005 | 01:54 PM
c1500's Avatar
im pretty sure mine has aluminum...
Old Nov 18, 2005 | 03:37 PM
EvilChevy's Avatar
The heads on this engine are the stockers. But I might have the hook up on 2 6.0 HO blocks for $200.00 each . Stay Tuned for more info.
Old Nov 18, 2005 | 04:00 PM
budhayes3's Avatar
PT's Slowest Truck
The LQ9 (HO) and the LQ4 (from 01 and up) use the same aluminum heads, with a 317 casting. Main difference is the pistons and connecting rods. LQ9's are flat tops and the rods are a little heavier and stronger. LQ4's are dished.
99-00 6.0's have a longer crankshaft and iron heads.
Check out this thread:
https://www.performancetrucks.net/fo...39#post3207039
