6.0L swap info
Old May 2, 2009 | 08:36 PM
Neverdone's Avatar
A mail order or dyno tune, either will work. Tranny should survive for a while as long as you don't beat on it too hard. A transgo shift kit and upgraded servos would be a wise and relatively cheap investment. Your stock rear end will be fine, just don't go out and do a bunch of dough nuts.
Old May 3, 2009 | 12:50 AM
Parke10's Avatar
if you get really lucky a servo,shift kit, tranny cooler trany MIGHT last... and the rearend MIGHT last, yes if u dont beat on them...but 99% of ppl who are gonna do this swap are gonna beat on the truck alittle, thats why they do the swap..
Old May 3, 2009 | 03:23 AM
CashDudeHomie's Avatar
Don't forget to swap out your flexplate (make sure the 4L80E spacer comes out with the old 6.0 one) or you will be needing a new transmission in about a day.
Old May 3, 2009 | 11:28 AM
Parke10's Avatar
Ooops thanks for adding that, i completely forgot about that
Old May 3, 2009 | 11:57 AM
GMCtrk's Avatar
Your flexplate will work just fine if you get an LQ9 or a LQ4 out of a denali. If it comes out of a 2500HD or van then you'll need the flexplate. Also, your trans and rear end will be fine. Ive been on my bone stock trans for a year with the 6.0. I dont drive it too hard though.
Old May 3, 2009 | 12:03 PM
Parke10's Avatar
you were the 1% i was talking about when i posted that lol, because i had remembered reading about yers lasting when i 1st started wondering myself.
Old May 3, 2009 | 11:25 PM
getonit's Avatar
You can car your pcm to the dealer and have it flashed fairly cheap.
Old May 3, 2009 | 11:33 PM
getonit's Avatar
Flxplate and tune and everything else is a direct replacement
Old May 4, 2009 | 06:31 PM
Brandon511's Avatar
what is a flexplate,try not to laugh.if it doesent come with one are they expensive to buy?
Old May 4, 2009 | 08:36 PM
budhayes3's Avatar
PT's Slowest Truck
Flexplate, automatic transmission version of flywheel. It is bolted to the rear of the crankshaft and the torque converter is bolted to it. Just re-use your current one
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Aug 10, 2015 07:19 PM
Denali08
Aug 9, 2015 04:34 PM
gtyler04
Jul 28, 2015 06:21 PM
oharajo
Jul 18, 2015 09:24 PM
