6.0L question
Old Dec 28, 2003 | 09:36 PM
4x4Sierra2500's Avatar
Default 6.0L question
I am looking to swap in a later model LQ9 service replacement engine, but have a question. I know the earlier models used a longer crank to mate to the 4l80E, how did they do it in later models? Did they use a spacer behind the flywheel? If so i could just buy that, right?
Old Dec 28, 2003 | 10:05 PM
They do use a crank spacer to mate to a 4L80E,I had to put one on my 5.3 to run a 4L80E.Be sure that you get the longer bolts to install the spacer.
Old Dec 28, 2003 | 10:32 PM
Cool, thanks. Anything else different about it? Like did you use your stock flywheel and starter, or one for a newer 6.0L?
Old Dec 28, 2003 | 10:40 PM
I was swapping a 4L80E into a Tahoe with a 4L60E so I had to change the flywheel and my starter still worked.On a 2500 you shouldn't have to change anything,just add the crank spacer to your motor and bolt everything back the way it was.
mikeyjm1
17
Oct 29, 2015 11:04 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
jleews6
Sep 8, 2015 10:17 AM
