Is the 6.0L Internally or Externally balanced?
Old Sep 25, 2007 | 10:17 AM
Yogi Bear's Avatar
Originally Posted by Igles
so the spacer from the 01'+ would just make it worse?
Yes it would.
Old Sep 25, 2007 | 11:24 AM
Quik's Avatar
5 year bitches!
the spacer for the 01+ is to allow it to work with the 80....a 00 motor has this built in. GM never intended for the first 6.0s to be "hot rodded". they swapped to the aluminum head 6.0 and then used the standard lenght crank. making the 00 motor worth less, minus it being a core
Old Sep 25, 2007 | 01:28 PM
MGMC's Avatar
12 Second Club
so thats why you have to swap the flex-plate, i see now. are the 4.8-5.3 flexplates the same? i got an 05' 6.0 im putting in place of my 04' 4.8
Old Sep 25, 2007 | 03:38 PM
Quik's Avatar
5 year bitches!
a 4.8,5.3,LQ9,ls2, ls1 and etc have the same flexplate....the LQ4 is different but can use any of the above flex;s
Old Sep 25, 2007 | 06:11 PM
Phantom&RedGoat2004's Avatar
One word: Stroker.
Old Sep 25, 2007 | 08:49 PM
timmer1's Avatar
Tell me if I'm wrong, but I don't think my throwout bearing is completely fixed, appears to ride on a big spring, which may compensate for the 7/16".
Old Sep 26, 2007 | 08:25 AM
Yogi Bear's Avatar
I should have said that the pivot point is fixed. Of course, the bearing is moveable, but the range of motion is not adjustable - AFAIK.
Old Sep 26, 2007 | 09:48 AM
timmer1's Avatar
Could it be the same with a 2000 v6 and a 2000 v8, I measured from the transmission mounting point to the end of the crank, and it appears to be the same.
Old Sep 26, 2007 | 10:04 AM
Yogi Bear's Avatar
I was under the impression that the 2000 V6s, 4.8 V8s and 5.3 V8s were all the short crank and the 6.0 V8 was the long crank. But actual measurement will tell for sure. If you measure from the mounting face of the block to the flange face on the crank, and they both are the same, then I am wrong.
Old Sep 26, 2007 | 12:32 PM
Quik's Avatar
5 year bitches!
again the 00 crank is longer...there is no way around it. its longer...i can get you a pic today if you need more evidence. but its longer!!!!!!!!!!!!!!!!!
