Is the 6.0L Internally or Externally balanced?
Old Sep 19, 2007 | 12:47 PM
timmer1's Avatar
Default Is the 6.0L Internally or Externally balanced?
Hey guys, when I was shopping for flywheels, the guy asked me if my engine was internally or externally balanced. A couple of people told me it was internally balanced, but I thought I'd see what you guys think for verification. It's a 6.0L out of a 2000 Silverado 2500. Let me know what ya think. Thanks again.
Old Sep 19, 2007 | 12:51 PM
Quik's Avatar
5 year bitches!
internal
Old Sep 21, 2007 | 05:50 PM
Yogi Bear's Avatar
Is this the motor that you are tryin to swap into a V6 5speed? I believe that the '99 - 2000 6.0 had a longer crank. If you are trying to mate this 6.0 up to the 5 speed, I believe it's not going to fit.
Somebody correct me if I'm wrong.
Old Sep 21, 2007 | 06:50 PM
Quik's Avatar
5 year bitches!
yes it has the longer crank. its about 7/16 longer and currenty have one in the garage. dont think its goign to work either but could be wrong
Old Sep 21, 2007 | 10:39 PM
MikeGyver's Avatar
So if you stroke an '00 6.0 with a new crank, what needs to be changed to mate the Eagle crank to the '00 4L80E?
Old Sep 21, 2007 | 11:02 PM
Quik's Avatar
5 year bitches!
use a spacer off a 01+
Old Sep 22, 2007 | 09:41 PM
MikeGyver's Avatar
OK, thanks.
Old Sep 24, 2007 | 07:29 PM
timmer1's Avatar
I bolted my transmission up to it, and everything seemed to go together alright. I have the 5 speed and don't know if that makes a difference. I didn't have the clutch or flywheel on the engine, I was just maching it up, just to make sure the bolt pattern matched up. If that bolts up fine, doesn't that mean it'll work? I did a little measuring, and it appears to be the same.
Old Sep 25, 2007 | 08:59 AM
Yogi Bear's Avatar
The block and the bellhousing will mate up fine - that's not the problem. The problem is the flywheel and clutch. With the long crank, the flywheel will be approx. 7/16" closer to the tranny. Since the location of the throwout bearing is fixed, it will have the same effect as pressing the TO brg. 7/16" closer to the clutch, which will keep the clutch from engaging. Also, the input shaft on the tranny will be 7/16" further into the crank which could cause clearance problems and pilot brg. issues.
You have to get a shorter crank.
Old Sep 25, 2007 | 10:08 AM
MGMC's Avatar
12 Second Club
so the spacer from the 01'+ would just make it worse?
