6.0L and engine covers/ LQ4 LQ9 Question
Old Aug 26, 2004 | 03:41 PM
Ryan K's Avatar
Pathological Modifier
Default 6.0L and engine covers/ LQ4 LQ9 Question Pictures
Which plat forms got the full engine cover for the 6.0L? I have a 2003 2500HD and it only has the center cover, not a full center/left/right. So which got the full? Was it just the Denali 2500's or Escalades?
How can you tell externally if its an LQ4 or LQ9?
Ryan K.
Old Aug 26, 2004 | 03:42 PM
CHAGO's Avatar
Ryan K.
I dont think you can tell externally the difference unless you take the heads off and view the pistons.
Old Aug 26, 2004 | 04:49 PM
Ryan K's Avatar
What do you guys think?
Old Aug 26, 2004 | 05:57 PM
GMCtrk's Avatar
full engine cover should be the lq9
Old Aug 26, 2004 | 06:40 PM
gonzo 6.2's Avatar
Dont expect it to be a LQ9 just because it has full engine covers.Just did heads/cam ect. on a 02 denali with full covers,its a LQ4
Old Aug 26, 2004 | 07:53 PM
Ryan K's Avatar
so is there any way to tell externally?
Old Aug 26, 2004 | 08:18 PM
SSMinneapolis's Avatar
the engines are pretty much the same. only difference is the pistons.
Old Aug 26, 2004 | 08:25 PM
Black04SS's Avatar
Ryan do you know what the engine came out of?
Maybe you could do a cranking compression check and compare it to a known engine.
WP
Old Aug 26, 2004 | 10:19 PM
Black04SS's Avatar
On second thought,,,,,,,,,,,,,,Bore Scope.
Most small airports that do maintaince have them.
$50 and 5 min. No guess work.
WP
Old Aug 27, 2004 | 10:03 AM
Ryan K's Avatar
So, there is NO way to tell, with out knowing the donor vehicle.... So, what came with the LQ9?
Chevy SS trucks
Caddy Escalade
anything else?
