6.0L Build, questions on CAI and TBSS Intake manifold
To keep it short, I am building a 6.0 with 243 heads and thinner head gaskets. Comp is going to be 10.9:1 and I am going to be running a TR220 cam (or something with specs close to that) and long tube headers. First question is, is the stock intake tract capable of flowing at least 750cfm? I don't want to run a CAI if it's not necessary. I don't like all the obnoxious intake noise and don't want to hear it if I don't have to. Secondly, I am being offered a complete TBSS LS2 intake with injectors, fuel rails, the whole ****'n'sha-bang for $350 with engine cover. Is this a good deal? Even if this is a good deal, will I benefit from this intake and 90mm throttle body on a mild build such as what I'm doing? Anyways, I am hoping to be knocking on the 400RWHP door and running low 13 second 1/4 mile. Do you think this is realistic with this setup? Thanks in advance for your input.
Do know that this engine is going to be designed for the broadest possible torque curve possible. Rarely will this motor see a 6200 RPM+ shift unless it's a heated stoplight battle. I am in search of nasty torque that will vaporize the tires at will. This is a 5 speed truck so I'm not wanting any cam surging at idle or lower creeping RPM's. My driving style during the week consists of a lot of 600 RPM idling IN GEAR putting in rush hour traffic and I don't want the truck surging or lashing at those lower RPM's. I'm afraid I would get that with anything larger than a 220
i drive my truck every day with a 230/226 cam and i have no problems..as long as it is tuned right you shouldnt have any surging or any problems..and i can blister the tires with no problem at all
Do you have any dyno sheets from your old 6.0
