6.0l build
Old May 13, 2013 | 04:02 PM
farmrowe1's Avatar
Default 6.0l build
Hey guys I have a 2010 2500 with the LY6, I have already added a cold air intake and a throttle body from airaid and an edge evolution programmer. It has a 6'' lift with 32'' tires. I do some heavy hauling but mostly want to play. I’m thinking long tube headers, new cam, new EMS, maybe some more internal work and for the final piece a Whipple of magnuson charger. I just was looking for some recommendations for brands/ grind for cam or really any help. I am pretty new to this stuff but am trying to teach myself. Also would 4.10 gears be worth it? Thank you!
Old May 13, 2013 | 04:22 PM
low2001gmc's Avatar
definitely long tubes, about a 224-230 blower cam (some with a 6-8 degree split duration due to rectangular port heads), ems???, a 3200 stall for daily driving.
gears be worth it since you got 32 tires and assuming you got 3.73s, with them 32 taller tires, they acting more like 3.42 or smaller. so 4.10s would help greatly in getting that heavy rig going.
Old May 13, 2013 | 06:34 PM
farmrowe1's Avatar
yeah I’ve got to do long tubes, I’m thinking ceramic lined. and a blower cam? is that something that i would have to get custom or could crane do that? and new engine management system, but yeah i forgot about a stall thank you. and yeah I figured I would have to get gears, do you know anything about getting new push rods or anything else inside the engine?
Old May 13, 2013 | 07:10 PM
03sierraslt's Avatar
The factory computer will handle your plans just fine, you dont need any type of different controller until you start getting pretty damn crazy with power output. What are your power goals? When you change the cam you will want to upgrade the valve spring and pushrods also.
Old May 13, 2013 | 07:24 PM
farmrowe1's Avatar
so just the chip will handle the work i want? and as much torque as i can get with out destroying anything, but ok thats what i was wondering so new rods and springs? do you think i will need new injectors or rails?
Old May 14, 2013 | 10:53 PM
Fbafbnwen's Avatar
Registered User
Old May 16, 2013 | 12:35 AM
farmrowe1's Avatar
Yeah im doing long tubes for sure i just dont know about keeping cats, and do i run 3 1/2s or do i go down to 3
mikeyjm1
17
Oct 29, 2015 11:04 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
jleews6
Sep 8, 2015 10:17 AM
