6.0 what headers to get??
Old Jul 24, 2008 | 09:16 PM
20inch8lug's Avatar
Default 6.0 what headers to get??
i have a gmc sierra 1500 hd. what headers should i get and what else do i need to make them work, move cats get rid of cats etc..... can i run no cats and not have problems with the truck or inspections? ilive in new york. also i have a slp diablo programmer, do i need it reprogrammed or can i do what i need to do myself in the options? thanks for ur input
Old Jul 28, 2008 | 01:35 AM
acethedragon's Avatar
being in new york, i am pretty sure you have to keep your cats. you will want long tube headers cause shorties are identical to stock. most lt headers require custom work to attach cats. the only one i can think of that doesnt is the dynatech supermaxx set. comes complete with headers, cats and y pipe.
Old Jul 28, 2008 | 10:23 PM
Get some Dynatechs!
Old Jul 29, 2008 | 08:54 PM
20inch8lug's Avatar
thanks guys but how bout sumyhin that will be a little cheaper. the sets i looked at are like a 1000 bucks.
Old Jul 29, 2008 | 09:04 PM
00Silv4.8's Avatar
yeah, screw dynatechs. Get some Pacesetter LTs (ceramic coated if u want them to stay pretty, or even high temp paint on painted ones.) Then go to a muffler shop, have them put one or both of ur factory cats in (say a y pipe off the headers into a single then put a cat in then a muffler, or whatever u wanna do.) But being in NY and me knowing nothing about their smog laws I'd say stay on the safe side
Old Jul 29, 2008 | 09:17 PM
dewmanshu's Avatar
Moderately Differentiated
Yeah I have dynatechs, unless you want to speed the cash just do what he says. Just make sure you coat them and coat them well. You want every single degree of heat to go with the exhaust stream. You will have better chances of the O2's not giving you any troubles. (they need that heat to test properly) Keep the cat's in NY. That diablo as far as I know want help ya much with a header install.
Old Jul 30, 2008 | 02:02 PM
skyhighsami's Avatar
no title here
I don't know how your exhaust is but I have an 03 1500 HD an it is dual pipes all the way to the muffler no Y pipe needed and to me the cats look to be far enough back that no changes to the cat's location is needed. I was just going to get some LTs and have them welded to the rest of the system. To me I see little advantage of the pipes merging into one off the headers. I have a dual inlet single outlet Magnaflow on the truck and it seems to be fine. Just something to think about before you buy a Y pipe you might not need.
Old Jul 30, 2008 | 10:31 PM
silveradol33's Avatar
get the pacesetter lts, and the ory after u figure out if u have to keep cats or not. I love mine!
Old Jul 30, 2008 | 10:39 PM
silveradokidd_4518's Avatar
+1 for Pacesetters
Old Aug 1, 2008 | 11:42 PM
ou812sm's Avatar
look in to obx headers about 500. shipped and they are 304 stainless steel mine were apefect fit
