6.0 swap, truck wont start..
Old Apr 4, 2007 | 01:54 AM
thunder550's Avatar
High on diesel fumes
Did you get all three ground straps on the back of the block? Two go to the actual block, and one goes to the back of the passenger cylinder head.
Do you have a fuel pressure gauge?
We need to figure out if it's fuel or spark you're not getting.
Old Apr 4, 2007 | 10:50 AM
ridnlow's Avatar
i pulled the intake last night to look for that knock sensor and im getting fuel... i think ive only got two grounds going to the engine.. ground strap and the one coming off the harness on the left side... where is the other one??
Old Apr 4, 2007 | 10:54 AM
Tootall's Avatar
one to the left of the crank sensor, on on the back right side, of the block, bolts to a non bell housing bolt, and then the fat ground strap to the back of the head
Old Apr 4, 2007 | 11:00 AM
ridnlow's Avatar
is the crank sensor behind the intake on the block?? there is a square and round plug side by side..
Old Apr 4, 2007 | 11:21 AM
Tootall's Avatar
hey I'm sorry CAM sensor . . not the crank . . . the crank sensor is on the left bottom side, next to the starter
Old Apr 4, 2007 | 02:57 PM
ridnlow's Avatar
Ive got fire and fuel at the rail (took the cap and pressed the little button) but still no crank.. could the injectors be bad??
Old Apr 4, 2007 | 03:08 PM
LesPaul's Avatar
swap out the rail and injectors from your old engine...
Old Apr 4, 2007 | 04:04 PM
ridnlow's Avatar
Got it running, it was the injectors.. Thanks a ton guys..
Old Apr 4, 2007 | 04:56 PM
LesPaul's Avatar
should have told you to do that before.... my injectors didn't work either and i swapped em out and it worked fine... NOW GO GET US A VID!@!!!!
Old Apr 4, 2007 | 05:06 PM
agreif's Avatar
Are the 6.0 injectors different than the 4.8 and 5.3? I didn't think they were. Is bad injectors common with 6.0 swaps?
