6.0 swap ?'s
Ok I have done some researching here and on other sites. Hi my name is Chas and I am a powerholic..... I want to do a 6.0 swap just like everyone else. first of all, what is the best motor to do it with. It is going to be a DD and it is 4wd so I do take it offroading a bit. I want something that has a ton of power but don't want to throw more than 2-3k into the project. No FI yet. I want to build a reliable truck with more power is my goal. Track times don't matter. (I have a 5.3 with intake and full exhaust and custom tune now)
what motor, cam suggestions, other components, is it possible, should I just bore out the 5.3 and do some mods to it?
i found an LQ9 for less then 1300 and everything from my 4.8 will swap right over.
Same goes for your 5.3. and id say for a cam maybe something in the 218-220 range youll also have to upgrade springs and pushrods for the cam
I may be wrong but to bore your motor to say 5.7 may be an option for you but doing for under 3000 might not be doable
GrooveCityZ71
Aug 31, 2015 12:05 PM
