6.0 swap complete, have problems w/questions
Old Jun 24, 2008 | 07:29 PM
  #21
Zick's Avatar
Either a dead battery (which I doubt since you said it worked fine on the 4.8) or you got a bad connection or missing ground.
I know when I put my 6.0 in, I couldn't get it started a few times. Like I had a dead battery or something. Turned out that my ground strap that went to the driver side of the block wasn't making a good connection.
How do your cable look? Any corrosion showing on them? Also feel the battery cable wires, if you got a bad connection, the resistance will cause the wires to heat up.
Old Jun 24, 2008 | 07:38 PM
  #22
agreif's Avatar
check your connections and especially all your ground again. Step 39: http://bertok.us/agreif/engine/EngineSwap.htm
Old Jun 24, 2008 | 07:55 PM
  #23
GMCtrk's Avatar
just got back from autozone, result: good battery. So it's either a missing ground or a bad starter which is what they thought it sounded like at autozone.
Old Jun 24, 2008 | 08:13 PM
  #24
GMCtrk's Avatar
It will start, just extremely slowly. Also, it really only starts when it's cold rather than when it's warmed up. I did a search and found a post stating that starters tend to be going bad when they don't start when warm. I already bought the new starter off ebay so we will see if that works. I'll also have the tech check the voltage at the starter.
Old Jun 24, 2008 | 10:41 PM
  #25
GMCtrk's Avatar
Here's a sound clip I took of the truck starting:
http://www.youtube.com/watch?v=nSAnp5Akn7A
Old Jun 24, 2008 | 10:59 PM
  #26
Zick's Avatar
Yeah you'll be amazed at how bad a starter sounds when it's not getting it's full power.
I just had a car that sounded just like that. Found it had really corroded positive & negative cables. After replacing them it started awesome.
Old Jun 25, 2008 | 01:35 AM
  #27
GMCtrk's Avatar
I took off the (+) battery cable and it was very corroded and rusted but everything worked fine with the 4.8. But I think the starts were not as strong on the 4.8 as they had been in the past. Given the fact that the LQ9 is higher compression I don't know if the starter had enough left in it to get the job done. We will find one when I get the new starter put in.
Old Jun 25, 2008 | 01:06 PM
  #28
Zick's Avatar
I still bet on a bad connection somewhere or possible bad starter (but that would be quite a coincident if it worked fine in the 4.8 before hand).
The starter may not all be the same but I haven't heard of a single person who went from a 4.8/5.3 to a 6.0 and complained about slow starting.
Let us know how the new starter works. Btw, what kind of starter did you get (stock 6.0)?
Old Jun 25, 2008 | 01:12 PM
  #29
GMCtrk's Avatar
Yeah, I got a new 6.0 starter. It's rated at 1.7kW whereas the 4.8 was 1.5kW. I also do know that before the swap the starts were not as strong as they used to be. Combine that with the higher compression engine and I think that may be the problem. I just fail to see how it could be a bad connection when the starter will turn over when cold but not when hot. The starter should arrive tomorrow but it will be a bitch to install since I have no jack, I'll just have to crawl under there.
Old Jun 25, 2008 | 01:29 PM
  #30
Zick's Avatar
No factory jack? What would you do if you got a flat?
