6.0 swap
Old Jan 30, 2011 | 02:33 PM
gnfan's Avatar
Default 6.0 swap
Any body know where to buy a custom converter needed to swap in a 2000 long snout crank 6.0. the truck is a 02 5.3 4l60. The Problem is the rear of the crank sticks out a lot further on the 2000 6.0 than the 5.3, looks like the only solution is a custom converter. Thanks for any help!
Old Jan 30, 2011 | 05:03 PM
gnfan's Avatar
Originally Posted by neilownz
Yank will do a custom one but it's spendy from searching other threads.
Also found this:
you can run a 60e behind it.. just drill the 80e flexplate to the 3 bolt 60e pattern and do not use the spacer.
Maybe contact tci about this part.
http://www.performancetransparts.com...flexplate.aspx
Thank you for your help...have to try to find a used 4L80 flywheel then.
Old Jan 30, 2011 | 10:04 PM
gnfan's Avatar
Also found this:
Is there a certain year of 4L80 flywheel you have to use?
Old Jan 30, 2011 | 10:42 PM
Sinistersilverado's Avatar
So does this have to be done to any 6.0 swap you do? I have a 2000 1500 with a 5.3 and i'm planning on swapping in a 6.0 out of a 2005.
Old Jan 30, 2011 | 11:27 PM
gnfan's Avatar
Also found this:
No problem on a 05, as it doesn't have the long snout crank. It's just the early years like 99 and 2000 from what I have found so far.
Old Jan 30, 2011 | 11:58 PM
gnfan's Avatar
Is that the TCI flex plate pictured?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
