6.0 swap
i have a 4.8 which is not good enought right now. im wanting to swap in a 6.0 either a lq4 or a lq9. but i wanna forge it for i can put the procharger i currently have and let it boost up to 15.
what am i going to need for the swap and what do yall guys recomend.
will my 4l60e bolt up to it.. i dont wanna get rid of it cuz its a stage 3 tranny fully built . but i need some help on what all am i going to need for the swap and if the tranny is going to bolt up against it and where can i get the forge pistons..
the trans will bolt up (if the crank is an 02+) but I can take a wild guess and say it wont last. Do a search on forge pistons for the 4.000" bore.
the swap will bolt right in, harness and everything. You will need a 6.0 tune flashed in to the PCM and then start from there.
the pistons should be fine.. if the timing is conservative.. but the trans prolly wont be too enthused about the new found power..
how about a lil more info on your truck.. all we know is it has a 4.8..
GrooveCityZ71
Aug 31, 2015 12:05 PM
