6.0 swap = Throwing codes
Old Jun 22, 2008 | 07:34 PM
drkblusierra's Avatar
Default 6.0 swap = Throwing codes
Well finally swaped my 5.3 to a 6.0 yesterday and have gotten the codes po171 banks 1&2 and po174 bank 1&2 i checked for vaccum leaks by spraying the intake manifold with no jump in the idle checked a spark plug tip and its like a off white color. i installed delphi 42# injectors with the motor swap. What to do next?
Old Jun 22, 2008 | 07:43 PM
gao8302's Avatar
Have you retuned it yet?
Old Jun 22, 2008 | 09:03 PM
yep its running a wheatley tune
Old Jun 22, 2008 | 09:32 PM
heres photos of the spark plug, i should also mention that the truck doesn't like to start until i crank it about 4 times.
Old Jun 22, 2008 | 09:34 PM
gao8302's Avatar
Looks lean to me. Get it checked out.
Old Jun 22, 2008 | 10:06 PM
im assuming you mean contact wheatley, do you think my starting issue could be from running too lean?
Old Jun 23, 2008 | 01:19 PM
Wheatley's Avatar
Truck Sponsor
I am sending you out a retune
Old Jun 23, 2008 | 03:06 PM
Thankyou Wheatley! I appreciate you being on top of this for me! Im sure you know but sent you a email with the freeze data from the scanner if that helps you... Thanks again!
Old Jun 23, 2008 | 03:17 PM
Wheatley's Avatar
Truck Sponsor
Yes sir I did get that,check to make sure you have no vaccum leaks or anything also
Old Jun 23, 2008 | 04:10 PM
yep, i will double check everything!
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chevyl33
Aug 24, 2015 08:21 AM
texasglock23
Jul 29, 2015 11:23 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
