6.0 stroker kit help!
Old Feb 1, 2013 | 06:00 AM
2006cory's Avatar
Exclamation 6.0 stroker kit help!
I just got a 6.0 an it needs rebuilding. I want to go with a stroker kit an I'm not sure witch 1 to go with. It's going in a 2006 rcsb. And it's a weekend warrior an going to the drag strip some! Just need some info an opinions thanks ppl.
Old Feb 1, 2013 | 08:02 AM
kelsey_canard's Avatar
I'm also interested in what bottom ends are available for us. The one I really only hear about is callies.
Old Feb 1, 2013 | 08:59 AM
blade7022's Avatar
I went with K1 Technologies. They are a devision of Weisco. Fully forged cranks and connecting rods. Some others that come to mind are Eagle and Lunati. Check Texas Speed and Performance --------------->>>>>>>>>, they have a large selection of rotating assemblies.
Old Feb 1, 2013 | 10:33 AM
2006cory's Avatar
An What size stroker should I go with?
Old Feb 1, 2013 | 10:35 AM
2006cory's Avatar
Ill give them a call an see what they say about it an the set up I should go with to get a idea. Thanks
Old Feb 2, 2013 | 04:12 AM
dirt track racer 81's Avatar
Hit up one of the Scoggin Dickey guys on the forum. They will set you up!
Old Feb 2, 2013 | 06:16 AM
sand man's Avatar
talk to Beau @ SDPC , great guy
Old Feb 2, 2013 | 09:46 AM
2006cory's Avatar
Ill check them out thanks! And about what kinda hp would I be looking at with some 706 heads milled 40 an 5 angle valve job with ported bowls? And good cam with a 90mm intake/32lb injectors?
Old Feb 2, 2013 | 10:53 AM
I wouldn't even waste your time with those heads with the small valves and small ports.. Just my opinion.. Look into some l92 heads.
Old Feb 2, 2013 | 07:59 PM
2006cory's Avatar
Ahh dang got like 550 in just work on the heads so that's wasted then
