6.0 stroker kit help!
I just got a 6.0 an it needs rebuilding. I want to go with a stroker kit an I'm not sure witch 1 to go with. It's going in a 2006 rcsb. And it's a weekend warrior an going to the drag strip some! Just need some info an opinions thanks ppl.
I'm also interested in what bottom ends are available for us. The one I really only hear about is callies.
I went with K1 Technologies. They are a devision of Weisco. Fully forged cranks and connecting rods. Some others that come to mind are Eagle and Lunati. Check Texas Speed and Performance --------------->>>>>>>>>, they have a large selection of rotating assemblies.
An What size stroker should I go with?
Ill give them a call an see what they say about it an the set up I should go with to get a idea. Thanks
Hit up one of the Scoggin Dickey guys on the forum. They will set you up!
talk to Beau @ SDPC , great guy
Ill check them out thanks! And about what kinda hp would I be looking at with some 706 heads milled 40 an 5 angle valve job with ported bowls? And good cam with a 90mm intake/32lb injectors?
I wouldn't even waste your time with those heads with the small valves and small ports.. Just my opinion.. Look into some l92 heads.
Ahh dang got like 550 in just work on the heads so that's wasted then
