6.0 Radiator with K&N GenII??
Old Jul 23, 2004 | 09:42 AM
BigKID's Avatar
Default 6.0 Radiator with K&N GenII??
Got my new 34" radiator and two 16" Zirgo fans in and was getting ready to install them when I figured out that the GenII uses the bolt hole inthe upper subframe I need to mount the radiator. Plus the heat shield overruns the hole about two inches. It dosnt look like I can move the heat shield over any either. Anyone done this swap with a GenII? How about other intakes? Do they use that bolt hole as well??
Old Jul 23, 2004 | 03:03 PM
Yelo's Avatar
my Airaid intake used that same hole....but the heat-shield is smaller so it works just fine (and I have that radiator STOCK)
Old Jul 23, 2004 | 05:10 PM
goshawk23's Avatar
Truck addict
can you cut the heat shield? or notch it out so it would work.
Old Jul 23, 2004 | 05:44 PM
BigKID's Avatar
Not really cause then all the tranny and coolant lines would be inside the heat shield. Kinda defeats the purpous of a heat shield, dont ya think?
I am thinking I may just sell the GenII and fabricate me something else. I got all this room from the efans, why not use it.
Old Jul 23, 2004 | 05:46 PM
goshawk23's Avatar
Truck addict
ok i have a better picture i think of what you are doing. would dropping the filter down help. you wouldn't need a heat shield then. of course i might be totally lost as to what your doing. who knows.
Old Jul 23, 2004 | 06:44 PM
Get a volant cold air box and reuse the K and N tube... I have mine that way and the only screws that hold it together are at the bottom of the Volant box so you have no rad interference.
Old Jul 23, 2004 | 07:19 PM
OBXMarine's Avatar
I ran into this way back when I had to get the bigger radiator to fit my Flex-a-Lites. I thought it was just me since the FIPK is also for the 6.0l. Well, maybe there's a different model for the 6.0 trucks because I had to strongly finesse everything where it belonged. I even had to loosen up the coolant tank and angle it a bit to get an extra bit of room. No real fix, but it fits.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
old motorhead
Sep 29, 2015 08:22 PM
sTNT971
Sep 26, 2015 04:22 PM
