6.0 or ls1
Old Jun 10, 2004 | 04:17 PM
Default 6.0 or ls1
What type of power diff between 6.0 and ls1 if you were going to swap one.
seems like a lot of people have 6.0.
Old Jun 10, 2004 | 04:24 PM
either one is a good choice. I am personally goin with later on down the road a 6.0 then stroke it. The ls1 is lighter by about 80 lbs. Just depends on what you want, if your going to boost it or run nitrous the 6.0 usually is the pick of choice due to the iron block and it has a biger displacement. both good options. Also the 6.0 can usually be picked up for less money.
Old Jun 10, 2004 | 04:50 PM
what if a used ls1 for a $1000, what does a used 6.0 cost?
Old Jun 10, 2004 | 04:55 PM
Well a 6.0 will probably cost the same, but I haven't found to many ls1's for $1000. usually like 2500 or so, get a pull out with really low miles. either way I think the 6.0 would be cheaper atleast the lq4.
Old Jun 10, 2004 | 04:57 PM
blownZ71's Avatar
I have a feeling Scream will be in here soon. FYI he just did a LS1
Old Jun 10, 2004 | 05:02 PM
Scream's Avatar
MOOBIES Moderator
Heh....yeah, I went with the LS1 because I got a really really good deal on it, and it's lighter. The 6.0L isn't a bad choice at all, but even barring cost I still think that I would have picked the LS1.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
