6.0 lq4 question
Old Dec 16, 2009 | 11:25 AM
walledition's Avatar
Default 6.0 lq4 question
i wana buy a 6.0 lq4, i have been reading and searching here a lot... i see that more are going with the lq4... i was reading that i should go 2001+ how can i check that? the people im buying it from have many 6.0`s but have no idea what models they are, im checking the piston for sure so i know its a lq4...
Old Dec 16, 2009 | 11:46 AM
budhayes3's Avatar
PT's Slowest Truck
Look at the crank at the rear of the block, it should be almost flush with the rear main seal I believe, maybe sticking out 1/8". The 99-00 cranks are longer and stick out noticeably farther...someone posted pics of the two side by side, search this forum and the Internal Engine section and you may find the pics...
Old Dec 16, 2009 | 11:48 AM
Wilde Racing's Avatar
How do I change this text
Aluminum heads is easier, aluminum 317 cast = Good 01+..
Old Dec 16, 2009 | 02:34 PM
ok thanx a lot... i will check that and see if i can bring home a good lq4 and we will go from there...
Old Dec 16, 2009 | 03:37 PM
jiar577's Avatar
walledition I see you're in El Paso. Any good place there to look for a 6.0?
Old Dec 16, 2009 | 06:10 PM
jiar577 pm sent
Old Dec 16, 2009 | 06:58 PM
i found 4 6.0`s, 1 2001, 1 2002 and 2 2003 so i`ll take a 2003... let say i wana go turbo, how hard is it to go 11`s with that motor... i just wana start and i still need to study a lot
Old Dec 16, 2009 | 10:20 PM
budhayes3's Avatar
PT's Slowest Truck
Duh...yea lol, the 99-00's came with iron heads, easiest way to tell...
Old Dec 18, 2009 | 10:04 AM
ok the more i read the more i get confused on what i really want... if i wana make this thing stroker 408, different pistons, would it be better if i only buy the lq4 block and start buying the parts? i dont matter if this will take long i just wana make a good and fast motor
Old Dec 18, 2009 | 11:47 AM
silveradokidd_4518's Avatar
i would just buy the whole motor... tear it down and sell off what you dont want... if you decide you wanna do the 408 you can get a nice little price for the crank and pistons... its really all about what you really want your truck to do in the long run... if the 408 is in your budget, then go for it... if not, then stick with the 6.0.. could even just bore the motor .030 over using the stock crank and make it a 370 with a nice set of forged rods and pistons...
