6.0 LQ4/LQ9 rods
Old Mar 13, 2005 | 12:07 PM
99Silver6.0's Avatar
Default 6.0 LQ4/LQ9 rods
Thought I would post this pic. I finally found it on my computer. I think the LQ9 rod is pretty easy to pick out.
Old Mar 13, 2005 | 12:10 PM
mattrem's Avatar
I thought the only difference was the pistons? Interesting.
Old Mar 13, 2005 | 12:23 PM
nativetexan's Avatar
13 Second Truck Club
Wow. Thanks for posting.
Old Mar 13, 2005 | 12:43 PM
Green Thunder's Avatar
I have some pics of some nicely bent LQ9's I will see if I can find them!
Old Mar 13, 2005 | 01:16 PM
Post em up. I wanna see that!
Old Mar 13, 2005 | 01:48 PM
Jason H. Rea's Avatar
Smile
Will both those rods fit on the same Crank? What I'm asking is if I swapped the rods from a LQ9 into my LQ4 would I have to change the crank? or are the bases where the bearings are the same width?
Got any pictures of the top of the pistons side by side?
Old Mar 13, 2005 | 01:57 PM
I have them on a disk a work i will try and post them tomorrow
Old Mar 13, 2005 | 07:00 PM
multmigs's Avatar
Default cranks r the same
all 6.0 cranks r the same, the pistons/rods are what is different between the 2 motors, you should have no prob with putting one into the other, not sure if the piston ends are the same so I'd say use the ones meant for either...
legerwn
56
Nov 15, 2015 10:21 PM
ls1stang
Oct 15, 2015 11:41 AM
mitchellmade
Sep 27, 2015 08:27 PM
BigKID
Sep 22, 2015 09:59 PM
chvy=power
Sep 8, 2015 11:06 AM
