6.0 help
Old May 11, 2008 | 06:20 PM
BJW74's Avatar
Registered User
Default 6.0 help
i have an 01 gmc 2500 4x4 with a 6.0. first question is what kind of mods will improve mpg without hurting my wallet? second thing is when i take off it sounds like a jet is lifting off (the fan) does everyones 6.0 do this or is there something wrong?
Old May 12, 2008 | 07:50 PM
BJW74's Avatar
Registered User
anyone else have lift off in your 6.0 truck?
Old Jun 7, 2008 | 12:05 PM
lo&sloSierra's Avatar
its probably your clutch fan being engaged, that year they were still running off the motor
Old Jun 7, 2008 | 12:11 PM
sprayed8's Avatar
+1 probably the clutch.
as far as MPG mods, my personal experience is that the best things for mileage were the cold air intake, electric fans (also eliminate your takeoff feature), good tune, and exhaust. plus they will all make the truck more fun to drive.
Old Jun 7, 2008 | 08:57 PM
Navi's Avatar
I have basically the same truck but a chevy, just did the nelson tune and havent run a tank of gas out of it yet to check mileage but it appears to be doing better. Power wise obvious increase, also seems to run alot smoother and with less effort. The turck is running 315/75/16s
Old Jun 7, 2008 | 10:04 PM
jleonard711's Avatar
In order to get rid of the fan noise and also increase your milage, you should replace your stock clutch fan with the 05+ e-fans. They cost about $250 + $100 for a harness, and you'll get better mpg, more power, and less noise.
Old Jun 7, 2008 | 10:55 PM
if you go with the oem e fans u have to get the bigger 05 radiator, due to the fact the fans/fan shrouds are bigger, but u can always go with aftermarket fans that work just as well, http://nelsonperformance.com
has the fan harness
Old Jun 7, 2008 | 11:37 PM
budhayes3's Avatar
PT's Slowest Truck
has the fan harness
Since he has an HD he already has the 34" radiator, perfect candidate for 05 e-fans .
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
