6.0 heads on 5.7
Old Feb 23, 2005 | 05:56 PM
Default 6.0 heads on 5.7
I have a set of 6.0 heads and a 02+ zo6 cam. What performance would a N/A 5.7 ls1 gain with these heads and cam combo? Or woul it drop the CR to much?
Old Feb 23, 2005 | 09:40 PM
ktmrider's Avatar
Compression drop would negate any gains. It's a good idea if you are gonna go FI, bad any other way.
Old Feb 23, 2005 | 10:05 PM
78' Silverado's Avatar
Hey this is off topic....Where in west Texas do u live Im in midland. Sorry just wonderin lol.
Old Feb 24, 2005 | 07:46 AM
I live in Odessa, but work in Midland- Nice to see some one local!
Old Feb 24, 2005 | 07:47 AM
How much would I have to shave on the 6.0 heads to get CR back up?
Old Feb 24, 2005 | 09:53 AM
ktmrider's Avatar
I can't recall exactly, but there is a sticky note in the LS1/LS6 internal section dealing with head volume, CR, etc. It has a TON of good info in it...
Old Feb 24, 2005 | 01:28 PM
BigTex's Avatar
Its going to take about a .050 milling to get back to the 10.1:1 stock CR of the LS1. Thats too much in my opinion.
Old Feb 24, 2005 | 01:57 PM
jimmyblue's Avatar
I've been told that the CR drop (which is like 10.1->9.5:1)
will cost about 5HP. However, the truck head is a lot
better at mid and higher lifts than the LS1 head on the
intake side. For a stock cam there might not be a big
difference but from the charts I've seen, anything over
.500 lift is basically wasted on a stock LS1 head (though
duration, of course, is not). I think if you're going with
any kind of bigger cam the 6.0s make sense. Maybe even
more so for any poor bastards who're stuck with 91
octane.
Sure, you can do better, but probably not for the price.
Though a I guess a set of ported LS1s could be made to flow
as well. Thing is, by the time LS1s flow as well they may
have hogged off the features that make a decent low end
(swirl bumps etc.).
I have a 6.0 set that'll be going on mine.
Old Feb 24, 2005 | 02:59 PM
Yelo's Avatar
With that cam choice I'm pretty sure that you'll not see much difference between the 5.7 and 6.0 heads (assuming 241 and 317 castings) performance wise.....people are making BIG power numbers on stock-headed cam-only LS1's
FWIW.....I'm doing that swap in reverse tomorrow...I'm putting 5.7 heads on a 6.0 to bump compression another .7 and hopefully see better mid/high-lift flow numbers (but I DO have the old-school cast-ion 6.0 heads too)
Old Feb 24, 2005 | 04:18 PM
I have the 6.0 heads and 02+ ZO6 cam , a friend wants to put them on his LS1 TA, I told him it would drop his CR but he still wants to try them. According to the calculation in the LS1/LS6 internal section , it should just take .030 shaving to get cr back to 10.1- Someone please correct me if I am wrong. Does anybody have an idea as to how much HP would be gained.
