6.0 Head Q???'s
Old Jul 11, 2006 | 11:45 AM
912jonathon's Avatar
Default 6.0 Head Q???'s
i just bought a 6.0(lq4) out of a 2001. what is the compression ratio of this motor and would it be better to put a set of 241 casting heads on it?
Old Jul 11, 2006 | 11:49 AM
Yelo's Avatar
CR is 9.4:1 stock, 241 heads and .041" gaskets will get you closer to 10.3:1 (see my sig)
The stock 317 (6.0 aluminum) heads flow REALLY well, the flow numbers will drop with the 241's but given that the port volume drops as well torque will rise compared to the stock heads (valve sizes are the same between the two - 2.00"/1.55")
Old Jul 11, 2006 | 11:54 AM
what kind of hp are you pushing? and coulg i have the heads shaved some of leave them alone?
Old Jul 11, 2006 | 12:13 PM
Quik's Avatar
5 year bitches!
you could always run a 243 head which flows the same but smaller CC and nets you a full point in SCR
Old Jul 11, 2006 | 12:42 PM
Zick's Avatar
Old Jul 11, 2006 | 12:51 PM
Yelo's Avatar
I don't have a dyno sheet after my mods but given my 0-60 times and 1/4 miles passes (G-tech Pro) I'm guessing around ~425fwhp (340rwhp)
Like other said...the 243 heads are a better flowing head but are more expensive, harder to find, and the increase in CR might be more than you'll want to run (10.5:1 with stock gaskets, 10:6:1 with .041" gaskets)
Old Jul 11, 2006 | 01:17 PM
im going with the 241 b/c i have a spare set
so how much hp am i looking at if i install the 241 heads over the stock ones?
Old Jul 11, 2006 | 03:03 PM
Yelo's Avatar
Assuming everything else stays the same you're probably looking at a ~25hp gain due to the increase in compression, I wish I could give you a better guess but I did my heads/cam/headers/tune at the same time
Old Jul 11, 2006 | 03:11 PM
ok thanks for the info
Old Jul 11, 2006 | 04:41 PM
Bad_Apple's Avatar
Put your cam and them 241 heads on that 6.0L and a shot of gas and your going to be flyin. You can sell Brandon your 5.7L
