6.0 HD Vs. 6.0 SS?
Old Jan 5, 2009 | 06:15 PM
20inch8lug's Avatar
Default 6.0 HD Vs. 6.0 SS?
what is the difference between the 6.0 HD motor and the 6.0 SS motor? i have the hd and my buddy has the ss. the ss is so much faster. stock it was faster and even w/ both of us w/ bolt on mods and tunes he is faster even w/ mine having a coup[le more power adders. i know my truck is 300 or 400 lbs more but that shouldnt matter that much. i know some people doing some work to ss's and was wondering if any of there stock motor parts that i can probably get real cheap could add power to my motor.thanks for any info
Old Jan 5, 2009 | 06:16 PM
00ChevyScott's Avatar
Wearin' da big hat
6.0 in the HD is an LQ4, the 6.0 in the SS is an LQ9
Difference is piston tops, heads, and compression ratio.
Old Jan 5, 2009 | 06:30 PM
RandomHero's Avatar
Agreed, plus:
300-400 pound difference= .3-.4 difference
30-50 rwhp parasitic drivetrain loss compared to a 4l60e and 10 bolt= .3-.5 difference
Slightly more horsepower(I forget the exact numbers).
You are talking about a .8-1.2 second difference in the 1/4 mile
Old Jan 5, 2009 | 06:31 PM
20inch8lug's Avatar
hmmm so i see. so w/o spending some big cash i am screwed. lol. right now things are a little tight. is there any small budget things i can do so i can at least run with him if not **** on him(<---dreaming).
Old Jan 5, 2009 | 06:32 PM
20inch8lug's Avatar
forgot to mention right now its my daily driver too.
Old Jan 5, 2009 | 06:49 PM
XLR8NSS's Avatar
Adkoonerstrator
100 shot of nitrous!!
Old Jan 5, 2009 | 06:54 PM
20inch8lug's Avatar
i rather not spray. i rather have something that will help all the time. like with towing etc......
Old Jan 5, 2009 | 07:05 PM
GMCtrk's Avatar
heads are the same.
Your LQ4 is every bit as good as the LQ9. The only difference is that your pistons are dished. In fact looking back now, I prefer the LQ4 because it leaves a lot more options for ported heads while keeping a streetable compression ratio. Almost all the performance shops gear their heads towards the F-body guys which means chamber sizes 59-64cc. Well on the LQ9 that's 11:1+. Not very good, especially if you tow. I'd recommend you get some PRC stage 2.5 5.3l heads. I would have gone with those in a heartbeat if I had the LQ4, instead I had to go with 317s.
Old Jan 5, 2009 | 07:18 PM
ap2002's Avatar
yeah not much difference, but your truck is heavier plus has the 4l80e tranny so that alone kills alot when comparing it to the SS, i would suggest a custom tune and a small cam for that big pig and it should really wake it up, a 212/218 will work well in that heavy truck...
Old Jan 5, 2009 | 07:20 PM
03ssilverado's Avatar
From: On a one way dead end street... And I can't get out
I got a nice procharger that would help you out
