6.0 Cam In 5.3, Heads
Old Jan 11, 2005 | 07:43 AM
Default 6.0 Cam In 5.3, Heads
Would there be any gain, if any, by installing a stock 6.0 cam in a 5.3?
How about 6.0 heads in a 5.3, how much hp?
What if you both, the heads and cam?
Old Jan 11, 2005 | 07:55 AM
sfj
it would definately flow more but as far as a HP gain prolly not much cause your compression ratio will drop ALOT now 6.0 heads with FI you would be able to boost the whole shiite out of it
Old Jan 11, 2005 | 08:09 AM
Scream's Avatar
MOOBIES Moderator
I think the cams are the same...you could gain much more by going w/ an aftermarket grind or even an 02+ LS6 cam/springs.
Old Jan 11, 2005 | 10:44 PM
PappyDan's Avatar
Tribe Shaman
the last time i went to the dealership and asked about the cams in the 4.8 5.3 6.0
They were all under one that is 1 order number for a replacement.
All 3 motors run the same cam.
The 4.8 and the 5.3 have the same heads.
the 6.0 cost more and have better flow
Old Jan 11, 2005 | 11:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
The cams are the same accross the board.
GrooveCityZ71
Aug 31, 2015 12:05 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
06 4.8
Jul 15, 2015 07:17 PM
