6.0 CAM IN A 4.8!
Old Apr 16, 2002 | 09:47 PM
KRAZY J's Avatar
Default 6.0 CAM IN A 4.8!
Will a 6.0, 5.3, or even a LS1 cam work in a 4.8 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> If so what kind of horsepower gains would I be looking at?
<small>[ April 16, 2002, 10:21 PM: Message edited by: KRAZY J ]</small>
Old Apr 16, 2002 | 10:35 PM
WMSuperSport's Avatar
Default Re: 6.0 CAM IN A 4.8!
yeah, what lift are the 2000 4.8 springs good till? Can they handle the LS1 .500 lift?
Old Apr 16, 2002 | 10:49 PM
KRAZY J's Avatar
I dont know what the springs are, but I guess I need to find out because I can either get a 6.0 or LS1 cam for 30 bucks! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ April 17, 2002, 10:05 AM: Message edited by: KRAZY J ]</small>
Old Apr 16, 2002 | 11:13 PM
GREGGO's Avatar
Shouldn't be any problem. The heads on the 4.8 and 5.3 are the same. You may loose some low end with that cam. If your going through all this trouble, put in a 5.3 crank and rods. Then you will have a 5.3.
Old Apr 17, 2002 | 07:44 AM
BigTex's Avatar
Didn't the newer F-body go with the truck cam when they made the switch to the LS6 intake? I know the 5.3s got the 6.0 cam in 2000. Did the 6.0 cam get larger or change then? You better find out what year cam and the exact specs before you spend your hard earned $30. Even for $30, it isn't worth it if its the same cam you already have. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Richard
Old Apr 17, 2002 | 11:22 PM
graygmc's Avatar
in 2000 both the 4.8 and 5.3 got the 6.0 cam. so it would be pointless to get that one. i am pretty sure they havent change the 6.0 cam yet in 2002. i would go with a cam that produces torque since 4.8's basically have little torque.
Dan Neumann
11
Aug 7, 2022 09:06 AM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Suburban2500
Jul 19, 2015 04:50 PM
