6.0 build help
Old Mar 16, 2012 | 09:55 PM
Chevy Man 6's Avatar
Default 6.0 build help
I'm wanting to make 400hp at the fly wheel but be able to daily drive. Don't really want a stall if I don't have to. I've done alot of searches but no good answers. I'm not building a drag truck. Thanks for the help
Old Mar 21, 2012 | 01:25 AM
gonzo 6.2's Avatar
need good questions to find good answers
Old Mar 21, 2012 | 01:45 AM
AndysC3's Avatar
lq4 or lq9? the lq4 cam with 325 stock. Good long tube headers and exhaust, A TBSS or NNBS intake manifold with 90mm TB, and a good tune and you will be close. If you want a cam the 212/218 low lift will add more lowend torque and pull harder up top.
Old Mar 22, 2012 | 06:15 PM
Its a lq4 thinks for the tips
Old Mar 22, 2012 | 09:11 PM
zero2sixT's Avatar
You leave so much on the table with a factory converter. You can get a a mild converter and still dd.
Old Mar 23, 2012 | 06:40 AM
What about a tr220 and what stall
Old Mar 23, 2012 | 06:40 PM
zero2sixT's Avatar
tr220 is still pretty small for a 6.0, but will run good. Seeing that you didn't initially want to go with a higher stall converter, I'd say around a 2800. I'd give performance industries or yank a call, and tell them what I want out of a torque converter.
Old Mar 23, 2012 | 07:56 PM
grey matter 04's Avatar
13 Second Truck Club
vinci trucker 216/224 cam in that 6.0 will daily drive great on stock stall
Add a lil head work and 400hp is had
6.0 and a trucker cam has made 370-380 look up dyno charts
Old Mar 23, 2012 | 09:00 PM
With that stall would i have to change my gears i have the stock 342 gears right now want to put 373 with a limited slip later on
Old Mar 23, 2012 | 09:36 PM
zero2sixT's Avatar
No, gears can wait.
