6.0 block rear has a piece broken need help
Old Aug 14, 2005 | 08:48 PM
Dark Halo's Avatar
Default 6.0 block rear has a piece broken need help
I have bought a 6.0 LQ9, From what i can see the motor has very low miles on it but I am asuming the motor was replced due to the broken piece of the block. What I want to know is do you think this can be fixed? It will not interfear with the seal of the oil pan gasket it just will not allow you to tighten at this spot which would cause a leak. One idea I have is to drill the hole out all the way down for a longer bolt then maybe JB weld the broken spot to provide the flat surface. Just wondering what your ideas may be and if you think maybe a shop can fix it or can I do something myself to fix it? I have included a photo of the damage in order to draw a conlusion.
Old Aug 14, 2005 | 09:46 PM
white1's Avatar
You can just send it to me, and it will be my problem instead of yours
Old Aug 14, 2005 | 10:28 PM
Dark Halo's Avatar
I will keep that in mind but I think I will send you a cam instead
Old Aug 15, 2005 | 12:34 AM
Steve Bryant's Avatar
LS1 Tech Veteran
What bolts on at this spot?
I am pretty sure that your JB Weld idea would work.
Steve
Old Aug 15, 2005 | 09:37 AM
Gordy M's Avatar
Take the block to a good welder and have them rebuild the corner and then tap the new bolt hole. JB Weld is only for non stress areas.
Old Aug 15, 2005 | 09:40 PM
Dark Halo's Avatar
the oil pan bolts on here so I need something that will hold
Old Aug 16, 2005 | 08:52 AM
Nick™'s Avatar
I agree with having a welder rebuild it. once he's done grind it smooth, tap your new hole and it's done
Old Aug 16, 2005 | 05:54 PM
Dark Halo's Avatar
just need to find a good welder who can be creative with iorn
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Denali08
Aug 9, 2015 04:34 PM
vmaxpro
Aug 4, 2015 07:02 AM
steves86ta
Jul 28, 2015 10:21 AM
4B11T
Jul 13, 2015 03:48 PM
