6.0?
Old Jan 6, 2005 | 11:42 AM
Default 6.0?
What year of 6.0 was the bad year or is there a prefrence on wht year to buy
Old Jan 6, 2005 | 11:49 AM
99 and 2000 6.0s had CI heads and a thicker crank flange.
Old Jan 6, 2005 | 11:59 AM
Would it be best to use a 99 block with 2001 + heads
FILE's Avatar
2001+ have aluminum heads.
Old Jan 6, 2005 | 12:21 PM
sfj
in other words i would say yes to save the weight on the heads but that is just my opinion
Old Jan 6, 2005 | 12:38 PM
Flyer's Avatar
The crank on the earlier motors is longer too and won't work with the 60e trans.
Old Jan 6, 2005 | 12:45 PM
sfj
question?!?!.... how would a different crank cause it to not work with a 60e
Old Jan 6, 2005 | 12:56 PM
Flyer's Avatar
The end of it's sticks out further. In 2001 I think it is, they used the same cranks, but added the crank spacer on the flex plate instead of the added material on the crank to take up the space the spacer does currently.
Old Jan 6, 2005 | 01:04 PM
sfj
oh ok thank you just wondering
Old Jan 6, 2005 | 01:41 PM
So a direct repalcement will be a 2001+ ?
What do you need to install a 99-2000?
