6.0 5.7 5.3 4.8
Old Jun 26, 2003 | 09:57 PM
02gmc's Avatar
Default 6.0 5.7 5.3 4.8
im planning on removing my stock 4.8 aluminum heads
i need info on opinions on should i rework my stock heads or buy 6.0 5.7 or 5.3 heads and what combo should i use i dont want n.o.s. or forced induction so all opinions will be greatly apprecatied...
Old Jun 27, 2003 | 08:00 AM
1BADHD's Avatar
Default Re: 6.0 5.7 5.3 4.8
6.0 have the best flow #'s, from what I have been told.
Old Jun 27, 2003 | 08:04 AM
Flem's Avatar
actually the 4.8/5.3 heads are the same and are a very good head. all the other heads have bigger cc chambers and would drop your compression.61cc 4.8/5.3 64cc 5.7ls-6 67cc 5.7ls1 71cc6.0. go w/ 4.8/5.3 heads have them cnc'ed. you can't go any bigger than 2.00" intake w/the 4.8/5.3L bore. have the chambers reduced to around 58cc to bring you up to around 10:1 compression. then add a cam that will take advantage of the increased flow but be careful of your .050" duration #'s too big and you'll kill any of the low end the 4.8 has.
Old Jun 27, 2003 | 11:42 AM
00scsb325's Avatar
I know that with 5.3 heads if you get them reworked you can get up to 12:1 compression I believe, and will work with 93 octane. Not completely positive but pretty sure.
Old Jun 27, 2003 | 02:33 PM
GoldenVelvet's Avatar
The thing to do is put the 4.8/5.3 heads, with some port work, on a 5.7 for the bump in compression. That tells me that the 4.8/5.3 heads are good flowing heads. Have the heads worked over by some one that knows what they are doing.
Old Jun 27, 2003 | 04:11 PM
Grey Silver's Avatar
11 Second Club
Flem has some excellent advice on this. Bumping up the compression is a good idea for a n/a motor.They make 2 6.0 motors. The only difference is the compression. One makes 9.5:1 and the other makes 10.5:1 and claims 340 HP.
Old Jun 27, 2003 | 07:29 PM
GREGGO's Avatar
4.8/5.3/5.7 heads are the same. The diff is the combustion chamber between the 4.8/5.3 and 5.7 (LS1 heads)
LS6 and 6.0 heads are the same also with the difference being the chamber also (same "D" port exhaust).
Old Jun 28, 2003 | 02:51 AM
Yelo's Avatar
minor difference...but it's 9.4:1 NOT 9.5:1 and 10.5:1 for the LQ4 and LQ9 6.0 liters...I have been told the difference is in the head gasket...and I have a hard time believeing that 45 HP is gained by a head gasket change.....I am assuming there is a cam change as well ??
Old Jun 28, 2003 | 08:50 AM
BigTex's Avatar
Yelo - Same head gasket in the different 6 Liters. Same cam in the LQ4 and LQ9. The LQ4 has cast dished pistons for 9.4:1! and the LQ9 has hypereutectic flat top pistons for 10:1 compression. The 45 HP rating is due to the increased compression and better tuning.
Old Jun 28, 2003 | 01:14 PM
Yelo's Avatar
thanks for the correction and the info.....I thought the head gasket thing sounded a little fishy
